Dear Friends and helpers ....
I just get my new 106D and install it using the Nero 6.0 , in WinXP comp.
When I tried to burn a DVD , in file mode , the speed is not higher then
X2 and not X4 as in its data.
Any suggests what to do to get the X4 .
I am using DVD-R media .
10X
When you say 10x do you mean you have 10x dvdr disc's?
The drive will only burn at the speed the disc you are using is rated for, so......if you have a 1x disc in a 4x burner it will only burn at 1x . You need to get the 4x dvdr disc's so you can burn at max speed.
BTW 10x dvdr discs don't exist, 4x is the max -
Hi sLiMpAuLy,
10x is short for Thanks and not referring to the DVD media ...
Huntman69, a couple of things you can try:
1. check to see if the media is 4x
2. try upgrading the firmware
3. try with Nero 5.5.10.50 (which I'm using) instead of Nero 6.0
I'm currently also using the A06 flashed with firmware 1.07; no issues so far.
Cheers. -
Also make sure your ASPI drivers are all working properly. You can do this by downloading infotool.exe at
http://www.ahead.de/en/631940826989307.html
goto the ASPI tab and it will detect if all is well on your system. Sometimes when you uninstall a burning prog such as nero or easy cd it will uninstall your driver to. If this is the case just download the proper ASPI file(s) and install as per the readme text file. Hope this helps
BTW I feel like such a tool for not knowing 10x meant thanks
Much appreciate your HELP, Thank You.
I change to 1.07 , but it is strange , to go BACK to 5.5.10.50 and not
using the latest Ver. 6.0 .
Also, how can I know that the media I am using is 4X ?
Thank you again (10X.....
Pioneer DVR-520H: seeking advice for DVR-107-XA drive replacement.
By donglejack in forum DVD & Blu-ray RecordersReplies: 71Last Post: 12th Feb 2012, 08:24 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 19:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 17:26 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 07:20 -
Pioneer 106D & Maxell 8x DVD-R
By piano632 in forum DVD & Blu-ray WritersReplies: 1Last Post: 22nd Jun 2007, 17:38
