Hi
i've yet to buy a dvd burner but am trying to do my homework so i hit the ground running so to speak![]()
just wondering if it's possible to convert AC3 divx/xvid to DVD whilst keeping the AC3 sound intact? and if so is there a guide made for it or even better a one stop solution to save using loads of little proggies?
any help is appreciated on this cos i know a fair bit about vcd/svcd conversion but absolutly nothing about DVD atm!![]()
thanks in advance
You might want to consider getting the LiteOn LVD-2001 DVD player. This stand alone DVD player not only plays normal DVD discs but can also play DivX and Xvid from CD-R as well as DVD-R discs.
Thus no need to convert your DivX/Xvid files to MPEG-2 DVD format.
The unit costs around $140 to $150
I don't have one myself but I am thinking of getting it and probably would have one if it wasn't for the fact that I'm always too low on money hehehe
Here is a thread about it:
https://www.videohelp.com/forum/viewtopic.php?t=167658&highlight=
Yes, you can do it. Actually it makes things simpler, assuming you can author from M2V andAC3 files.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Piece of cake and quality is not bad at all, there are lots of walkthroughs on this site m8
'S' -
thanks for the response's
i thought i'd seen some sort of guides on the site earlier but wasn't sure if they were for AC3 or noti guess it'll all make a bit more sense when i've actually got my burner and i can play about properly!
re: the liteon player, i had no idea there was one out! i knew about the kiss player but it seemed to be near on impossible to get one in the UKbut i'm very impressed with the specs on the liteon and the fact that theres still loads more possibilties for it cos of the similarities to a PC
theres me wages spent again!
Rip DVD to Divx/Xvid with AC3 Audio
By dudeman316 in forum DVD RippingReplies: 6Last Post: 3rd May 2009, 03:25 -
MPEG4-AVC (H264) + AC3 -> Divx + AC3?
By thomas_fogh in forum Video ConversionReplies: 12Last Post: 1st Nov 2008, 20:25 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
Best (easiest) DVD to (DIVX or Xvid) with 5.1 (AC3) Audio out
By balagan in forum DVD RippingReplies: 5Last Post: 11th Dec 2007, 15:16
