HELP, the files I've converted from .avi to .mpeg1 in preparation for SVCD burining are too BIG.
For the last month I've been trying in vain to convert a number of approx. 750MB .avi files to SVCD/VCD using Virtual Dub, Cinema Craft Encoder, and BBmpeg for mulitplexing. I divide the .avi file in two with Virtual Dub, Convert with CCE, and Multiplex with BBmpeg. But no matter how many time I try to tinker with the settings and options of the software, a single 350MB .avi file (the original movie split in two) invariably grows to over 2 Gigabytes--way too big to burn on any VCD.
There must be some compression step along the way that I've missed. But i don't know what it is nor when to perform it.
I would be grateful for suggestions, guidance, enlightenment
Have you tried the Guides here? https://www.videohelp.com/guides.php?formatconversionselect=AVI+to+SVCD&search=Search+
There are many for avi - svcd, all highlighted for you.
A lot are made by the moderators of this forum. Try them. They're good for you. :c)There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
not a good start - SVCD is MPEG-2 (and so is DVD) - MPEG-1 is for VCD's.Originally Posted by mickey sabbath
If you want some basic advice, try learning the basics first.
CCE is not really the most user-friendly encoder out there - and you must be doing something very wrong if MPEG files that you intend to author to (S)VCD are coming out at 2gig+
As Gees says, take a deep breath, go and do some reading.
Learn about the different formats, and what a bitrate is etc..
Then you'll find you're able to answer your own question.
And finally, if you're going for (S)VCD, might I suggest that you give TMPGEnc a go - I'm making no comments about the quality difference between CCE/TMPGEnc, but few people would argue if I say that TMPGEnc is easier to use - and probably, therefore, better suited to a learner.
cheers,
mcdruid.
P.S. I'm really not trying to be rude to you here - I just think it looks like you're trying to fly before you can crawl.... and by-the-way, that's the best title for a topic I've seen in quite a while!!
macleod,
DVD2SVCD is very good - but it's not really free if you want to do MPEG-2 (SVCD/DVD) is it?
As far as I'm aware you need TMPGEnc Plus, Cinema Craft Encoder, or MainConcept MPEG Encoder - none of which are free.
mickey sabbath did say he's been using CCE already - so that may be okay, and of course you can use TMPGEnc for MPEG-1.
cheers,
mcdruid. -
you're right, it isnt free in that you have to purchase some type of encoder (basing my original answer on that the poster already had an encoder) to use the application, however, most people already have one of these encoders (I dont include it in my signature, because dont have enough room).
I recommend using dvd2svcd to everyone that is having an issue with converting a video from one thing to another as it rules out human error (if there is an error, they are asked to post the log) and usually dvd2svcd will allow them to automate the process better than they could ever do on their own.
Why is my sig so big?
By hech54 in forum FeedbackReplies: 1Last Post: 28th Apr 2012, 04:14 -
Big enough pc case?
By A Traveller in forum ComputerReplies: 39Last Post: 21st Aug 2011, 09:37 -
My compression is still too big
By NewbieAtDvdRipping in forum DVD RippingReplies: 2Last Post: 4th Jan 2011, 17:09 -
HD subtitles too big
By PSS2 in forum SubtitleReplies: 3Last Post: 23rd Apr 2010, 19:32 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2008, 00:51
