Results 1 to 11 of 11
  1. When I quick erase a DVD+RW in Nero or any other program, DVD Decrypter still thinks the media is not empty. It will ask me to overwrite, but this is keeping my AutoShrink 3.0 from completing the job without my intervention. Do I have to do a full erase? This takes some time.
  2. Banned
    May 2003
    Massachusetts
    You have to full erase at least once, in my experience.
    Also, I've had quite a bit of trouble on occasion getting certain +RW media to erase at all! The media is erased, the program doing the erasing knows it's erased, but other programs don't.
    Just keep trying. Erase it with a different program. Even a full erase only takes like 15 minutes.
    - Gurm
  3. Try erasing with DVDInfoPro. It does a good job of erasing RW media that other applications can't even erase or recognize. A free version is avaiable in the tools section. There's also an ad-free version which costs $20.
  4. @Gurm
    When you first use a DVD+RW it doesn't require full erase you can just write straight on it. Formatting goes in the background! At least on my Ricoh
    @jthomas5150
    Also DVD Decrypter is able to overwrite a disc that is not empty! Just click Yes!
    You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
    Dec 2002
    +RW is designed for overwriting on the fly (which is what you do for a quick erase anyway). Only a full erase actually resets everything, but it's an extra 15-30 minutes.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  6. @tompika
    Yeah, when using AutoShrink, I was just trying to get around clicking Yes when I do a 1:1 copy so it would be ready to watch when I get home from work.
  7. Originally Posted by jthomas5150
    @tompika
    Yeah sorry, that would be the point of using Autoshrink.
    A quick erase will do, don't worry.
    I suggest DVDInfoPRO
  8. Thanks everyone! I will try the suggestions. Keep up the good work!
  9. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    With Gear DVD (and the other Gear DVDV apps) DVD+RW are treated like RAM. I.e NO erase is required & it just overwrites your data with the new.
  10. You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
  11. Banned
    May 2003
    Massachusetts
    The problem is that sometimes, even if I _have_ erased a disc, some apps just don't seem to think it's empty. *sigh*
    I'll give DVDInfoPro a shot though.
    - Gurm
