Hello,
i'm trying to do as said in this article :http://www.tfdvd.com/public/123print.cfm
Making subpictures using photoshop layers and not only a 4 colour picture.
But as i have a pc and not a mac, i can't use dvd studio pro to do this.
I didn't manage to find out how to do this using dvd menu, photoshop, reel dvd and adobe encore dvd !!!
Do you have any solution ??
Thanks.
Thibault.
I would say based upon this statement:
For a single multi-layer menu, we're essentially designing a whole series of menus. Each separate menu in the series will represent ONE of the menu buttons in a different state; either the normal look of the button, the selected look (so the viewer knows where they are in the menu as they're deciding on which button to activate), and the activated look, or state.
This guide: https://www.videohelp.com/forum/viewtopic.php?t=140765
does the same.
I think the real trick is in the authoring, not Photoshop.I mean it in the nicest way.
Photoshop question (use layer names as text?)
By sdsumike619 in forum ComputerReplies: 1Last Post: 30th Apr 2009, 18:22 -
Picture as Menu Background in Adobe Photoshop
By boofer in forum Authoring (DVD)Replies: 3Last Post: 16th Oct 2008, 01:41 -
Motion Menu's - Where Do I Start? In Photoshop?
By EViS in forum Authoring (DVD)Replies: 11Last Post: 21st Aug 2008, 22:35 -
Need a Guide/Tutorial for Sonic Scenarist and Menu creation with Photoshop
By src2206 in forum Authoring (DVD)Replies: 4Last Post: 17th Oct 2007, 04:04 -
Photoshop question (applying a transparent layer to multiple psd's)
By Alex_ander in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2007, 08:34
