Hi,
I have done it! I've got 1 french film with english subs, ran it through DVD2SVCD using sefy's guide & it worked a treat, just got to burn it now. So thanks druid for pointing me right way.![]()
no problem - glad you got it sorted.
By-the-way if you post results/thanks at the end of the topic where the problem is discussed (rather than in a new topic) people searching/browsing the forum can see if people's advice solved the same problems they might be having.
cheers,
mcdruid. -
Hi Sefy,
Basically I could follow & understand it!!
Very, very newbie, can't follow advanced......yet! -
In that case, i'm very glad you found it usefull! makes the whole thing worth it!
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 08:22 -
Help with converting video / adding subtitles - subtitles are off from audi
By kurohoshi in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 15:53 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 17:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 09:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28
