  1. Hi All,
    Could anyone please advise. I have deleted an original video file from my hard drive by mistake. However, I have a VCD which I made earlier. Is it possible to rip the VCD back to my hard drive as an mpeg/avi etc so that I can do further editing.
    Many Thanks In Advance.
  2. as far as I remember VCDGear can convert the .dat file on your VCD back into an MPEG.
    However, unless you just want to cut/splice the MPEG, there's not much editing you can do to it without having to re-encode; and if you do that you'll lose quality.
    cheers,
    mcdruid.
    Aug 2002
    Dublin, Ireland
    There's several ways you can do this. I'd go for VcdEasy. In the tools section there's an option to disassemble a (S)VCD. You could also use IsoBuster.
  4. Many thanks for the help.
    Cheers
