When I try to use virtual dub to prepare movie for TMPGEnc and I set my video to direct stream copy and my audio to full processing mode I get this message:
The source video stream uses a compression alogorithm which is not compatible with AVI files. Direct stream copy can not be used with this video stream. Is there a way I can change this so it will work. Thanks for any help in advance.![]()
I tried this and it worked. I renamed the files from avi to mpg and they worked perfectly. Thats good for
It sounds like you may have just reversed what someone else had done before (i.e. changed the extension on an MPEG file to .avi)
You probably don't care now - but did you try seeing what gSpot said about your avi file? It will tell you what codecs are used in the file.
Lastly, if your file was really an MPEG - are you sure you need to re-encode it with TMPGEnc? You may just be losing quality for no reason.
cheers,
mcdruid.
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 13:24 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 03:46 -
Virtual Dub Mod Saving Problem
By cdgfx84 in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 13:08 -
Simple Virtual Dub Problem...
By tetzy in forum EditingReplies: 2Last Post: 22nd Feb 2008, 19:49 -
Ripping DVD & Virtual Dub Problem...
By Chana1 in forum DVD RippingReplies: 7Last Post: 8th Jun 2007, 07:45
