I made a backup of my childrens DVD, but there were many trailers in the beginning.
Doing the backup, I removed all languages but english, and all subtitles but danish (We live in denmark).
After doing the backup, I removed the trailers, using the VobRator and IFOedit, supported by a guide.
The guide described an example, where the trailers was located in the xxx_TS.VOB, but mine were in the xxx_04.0.VOB and xxx_04.1.VOB
Removing the trailers from the xxx_04.0 and xxx_04.1 VOBs solved the problem, and I could watch the trailer-free film from the files on the computer.
After burning the DVD, I could watch the DVD on the computer too.
But at the "normal" DVD-player (Denver -something, may be "160") the DVD wouldn't work. It started out showing the menues, but I couldn't select anything. Pressing PLAY, the film started with text in finnish, I believe, and still none of the menues worked.
What can the problem be?
All help and comments are appreciated!
Thank you.
Thanks for your reply.
I did use the DVDShrink to make the backup, but it wouldn't allow me to remove anything but subtitles and extra sound (speech in other languages).
The "film" parts I could compress, but not remove?
Or is there a way on the DVDShrink to actually remove parts of the video? -
Using DVDshrink version 3.2 and above you open the DVD then select re-author, click and drag the files you want then select crop which will allow you to set the start and stop points of the file. If there are numerous parts of the same file you need to edit out simply select the same file and crop as many times as required.
MPG files play fine on computer, no audio on DVD player
By kenimpzoom in forum Newbie / General discussionsReplies: 9Last Post: 16th Feb 2010, 15:07 -
Burned DVD from TV and won't play in computer
By dnlowe in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Sep 2009, 18:41 -
Burned dvd won't play in standalone player
By Shotobits in forum Authoring (DVD)Replies: 12Last Post: 13th May 2008, 02:21 -
x264 audio won't play in GB-PVR or WMP, works fine in MPC
By bigshotceo in forum Software PlayingReplies: 2Last Post: 15th Apr 2008, 10:55 -
converted vob files play on computer fine..skip when burned to dvd
By cduval04 in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2007, 19:26
