Okay, I have downloaded the trial version of VCDeasy. I have tried to open my videos I created using my Sony camcorder, but I am only able to select from the short MPEG clips that were created on my memory stick, right. So, I downloaded TMPGEnc, which only allowed me to view the MPEG's. I want to convert my DV to MPEG so I can burn that to a VCD that will play on most standard DVD players, so I downloaded Canopus DV Codec. Now I cannot open that application to use it! I am only a mediocre computer guy at that, and I am getting frustrated and tired. Please help me!
theguy
Well my suggestion isn't going to be free, but it will be simple to use (in my opinion). Get Editstudio and use that to edit you DV videos. Also get their mpegXS encoder to encode to mpeg1 or mpeg2 (incase you decide to go with SVCD or DVD). There is a demo for each, though the demo encoder has a watermark. Then take the finished mpeg1 into vcdeasy for authoring (chapters and whatnot). You might be able to find other tools listed in the tools section to your left that will accomplish what you need to do for free.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Unable to decompress your camera's image format cause a suitable codec is m
By cfairon in forum MacReplies: 2Last Post: 17th Jan 2011, 10:37 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 21:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 10:15 -
Recode Xvid/Ogg to PS3 Suitable Format
By mcompton69 in forum Video ConversionReplies: 2Last Post: 4th Sep 2008, 08:51 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 09:21
