Hi everyone
This is Cristian, from Argentina
I need some help here. It's not that I'm a newbie at all. I've been making VCDs for a long time, and I'm familiar with many programs, such as TMPGEnc, VirtualDub and even DVD2SVCD.
DVD2SVCD works perfect in my computer, but I got a friend that is trying to make it work and it always brings the same error at some point. Since my friend does not speak english, I'm asking for help for him
OK, he's got the same version of DVD2SVCD as me (1.2.1 Build 3).
Here is what he sent me:
WNASPI32.DLL 4.71.1.0
- 13/10/2003 22:10:31
- DVD to SVCD Conversion
- DVD2VCD ver. 1.2.1 build 3
Initializing
- E:\VIDEO_TS\VTS_01_0.IFO
- E:\VIDEO_TS\VTS_01_1.vob
- E:\VIDEO_TS\VTS_01_2.vob
- E:\VIDEO_TS\VTS_01_3.vob
- E:\VIDEO_TS\VTS_01_4.vob
Initializing finished.
- 13/10/2003 22:10:35
- Analyzing subtitles
Subtitle found: StreamID: 0x20 Language: Unspecified
Executing subtitle selection/verification.
Subtitle selection/verification accepted.
0 subtitle streams selected.
Saving Subtitles ini file
- 13/10/2003 22:10:58
- Free on drive C: 61410.81 mb
- vStrip
Preparing vobfiles to be ripped:
Saving the vStrip filelist:
- C:\Archivos de programa\DVD2SVCD\Movie\vStrip.lst
Executing vStrip. Commandline:
"C:\Archivos de programa\DVD2SVCD\vStrip\vStrip.exe" @"C:\Archivos de programa\DVD2SVCD\Movie\vStrip.lst" -i"C:\Archivos de programa\DVD2SVCD\Movie\VTS_01_0.IFO" -j1 -$1024 -p0 -o"C:\Archivos de programa\DVD2SVCD\Movie\VTS_01.vob"
- 13/10/2003 22:21:02
- DVD2AVI
Creating DVD2AVI INI file:
- C:\Archivos de programa\DVD2SVCD\DVD2AVI\DVD2AVI.INI
Variable settings:
iDCT_Algorithm: 32-bit SSE MMX
Executing DVD2AVI.
Executing DVD2AVI. Commandline:
"C:\Archivos de programa\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[C:\Archivos de programa\DVD2SVCD\MOVIE\DVD2AVI_Project_file] -IF=[C:\Archivos de programa\DVD2SVCD\Movie\VTS_01_1.vob,C:\Archivos de programa\DVD2SVCD\Movie\VTS_01_2.vob,C:\Archivos de programa\DVD2SVCD\Movie\VTS_01_3.vob,C:\Archivos de programa\DVD2SVCD\Movie\VTS_01_4.vob]
Analyzing DVD2AVI Project file
Force Film NOT activated!
Framerate: 29970
DVD2AVI processing done.
- 13/10/2003 22:26:58
- Free on drive C: 61410.28 mb
- AUDIO Extraction
Found AC3 stream id: 0x81
Filename: C:\Archivos de programa\DVD2SVCD\MOVIE\Extracted_audio_1.ac3
EAccessViolation Access violation at address 8407B000. Read of address 8407B000
So, I'm completely clueless about this error. Can someone help me find a solution to this?
Thanks SO VERY MUCH in advance)))))))
I'll be waiting online for any help to appear
Best regards
Cristian
I have used this program extensively. You may have another program or other versions of the programs within DVD2SvCD running that are interfering. If you haven't deleted DVD2SVCD and reinstalled, try that. Usually access errors are caused by corrupt data or corrupt memory, but usually that shows up during the encode, not during audio extraction. Try safe mode, sometimes that helps. Has he got enough memory installed? DVD2SCD can act strange at times. You might try an older version. Go to the DOOM9 site for more tips.
(http://forum.doom9.org/) -
Hi redwudz
Thanks so much for your help
Sadly, most of the things you pointed out we already tried, like trying old versions of the program, erasing everything and reinstalling. The machine has 256 of memory.
The only thing I couldn't find is the "safe mode" you mentioned. Where is it in the program?
Thanks so much
Cristian
PS: I've been looking for info at www.doom9.org but couldn't find anything at all related to this kind of error
Safe mode frameserving is under the encoder window, though I don't think that will help as it happens after the audio stage. I see you are using vstrip for ripping. Have you tried the internal routine instead?. If you haven't done it, you could run a memory test program, though as I said, usually memory problems don't show up till the encoder stage. Sorry, I don't have any more ideas presently.
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 00:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 16:08
