can anybody please give few recommendations for a good dvd backup prog which is easy to use and still remains reliable. my priorities are :-
good quality backups
reliability
ease of use
speed (as long as it doesnt take 8-12 hrs to backup i dont care )
i am using the nec1300 with the latest official 1.08 fw and windows xp pro with a celeron 800, which has so proved reliable and adequate at least until i try to re encode![]()
Results 1 to 16 of 16
Garry
well normally it takes more then one. what i use is DVD Decrypter Dvd2one and Nero. takes roughly a hour for everything thing could be faster but i use 2x media.
Good quality backup is the same whatever the media tape optical or hard disk. arcsoft veritas. few hundred quid. but your work is worth that right? cheaper? ghost or partition magic (copy whole partition if less than 4.3gb)
Or cheapest microsft backupCorned beef is now made to a higher standard than at any time in history.
In no specific order:
- DVD2One
- DVD Shrink v3.0 beta 5
- Nero Recode
- CloneDVD
- DVD95Copy
My favorite in terms of quality and flexibility: DVD Shrink v3.0 beta 5 (guides in my signature).
It's also free.
Originally Posted by RabidDog
are you sure your READING THE RIGHT THREAD???
Garry -
Hi
I've got the NEC1300a and I've been using CloneDVD with AnyDVD running in the background. Great - takes no more that 2 hours at 1-2 speed.
THe only problem was that without updating the 1300a's firmware to herries 1.05 it wouldnt work with CloneDVD it just took one sniff of a blank DVD-R and spat it out . . . ruined.
With the new firmware it runs a treat and works with cheap DVD-R media as well. I buy it from www.dabs.com @ approx £22 for 25 disks including postage and VAT.
garry, I use DVD Shrink 3.0 beta 5. Lots of versitility and fexability. Good transcoder, abilty to split, keep just movie, etc. DVD2One is also very good, but it is not free. Its main advantage is that it is very easy to use, but it has not split capability. Hope this helps.
You create your own reality. Interested in media servers and HTPC? Can we talk? -
I think Instant Copy is the best...Its kinda slow but the Q is really good...You can choose to make a 1:1 or just the main movie....Ive done about 150 movies and none of my friend can tell the differance..
DVD2one is fast
DVD Shrink is handy
CloneDVD cant work with my burner
NeroRecode I see no point of using it
Instant Copy I haven't tried yet but I will next weekYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Tompika
CloneDVD will output an iso DVD image file, which you can burn with whatever major burning program you've got that works with your burner.
Instantcopy on the other hand will not output a standard iso. The only option for recording to your HD is their crummy propriety format (pdi) which you then have to run through another program to get an iso (PDI2ISO).
I always burn from image files, never directly from the app. -
Yeah, thanks I'm aware of that but I still prefer DVDShrink and DVD2oneOriginally Posted by David K
I too like burning ISOs with DVD DecrypterYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
All those nero dvd compression programs
dont work for me either, they always just
seems to lock-up,i use dvd2one/shrink3/ic7,
ifoedit dont forget the man, and of course
dvd-decrypter....depending on the situation -
DVD Shrink is awsome and free. DVD Shrink is proof that the gods want us to make backups.
AMENOriginally Posted by Coaster Queen
PS: Could be a bit faster though....(but its free)You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
what cuesheet prog do u use
By mikeo1313 in forum AudioReplies: 2Last Post: 18th May 2010, 23:03 -
which prog to capture ?
By hydra3333 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 03:19 -
how can i Write And Encode 2-pass on same prog
By bassam319 in forum Video ConversionReplies: 4Last Post: 27th May 2008, 22:00 -
Which prog to get audio to work on DVD?
By bytheway in forum Newbie / General discussionsReplies: 2Last Post: 3rd Apr 2008, 19:40 -
What prog. encodes several videos without burning?
By Shapeup1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Oct 2007, 18:16
