I have a dvd that are tv shows that I want to convert to a vcd. There are 4 episodes on the on dvd when I try to convert them to mpeg it only converts one vob and only the first episode on the dvd. Can anyone help on how to convert the other files. Thanx
you can use DVD2AVI, it allows you to load several VOBs and pick a start and stop point (good if you just want to chop off stuff at the beginning of the first VOB and delete stuff after a certain point, editing in the middle you probably want something else to use).
You still will probably need to encode the output file as it will typically be in split AVI/Wav format, but it will have the 4 episodes you want... I usually run TMPGEncPlus to do the encoding...
Read This is you want some details...
How to convert DVD or SVCD to VCD with DVD2AVl and TMPGEnCendyne/Pioneer 105 & 104 with a Dazzle* Hollywood DV-Bridge.
Conversion issues with with 1. vob-file of a ripped dvd
By NSmooch in forum Video ConversionReplies: 5Last Post: 8th Jan 2010, 02:55 -
Conversion from VOB-File into a MP4 File stopps after 9 minutes...
By Fly Eagle in forum ffmpegX general discussionReplies: 2Last Post: 6th Aug 2009, 12:41 -
Loss of Audio During Conversion from VOB to AVI file
By dpvisco in forum Newbie / General discussionsReplies: 1Last Post: 13th Jun 2008, 02:21 -
VOB file conversion to AVI...many questions
By tonyclem in forum DVD RippingReplies: 19Last Post: 7th May 2008, 11:39 -
AutoGK DVD to DivX, which VOB file to pick for the conversion
By rhythmofthecosmos in forum Newbie / General discussionsReplies: 2Last Post: 11th Apr 2008, 15:25
