Silly question, but what do I need to edit video?
(OK... I've got the camcorder and a firewaire port.)![]()
But in terms of hardware what is recommended?
(I've got plenty of hard disk space.)
1. How important is a fast hard drive?
2. How important is a good graphics card? What is recommended if this is important?
3. What software is recommended?
4. What else is important?
Thanks.
Jam
You need to read the Guides. Start with these: https://www.videohelp.com/guides.php?howtoselect=1;54
Good glossary on this site too. Ask away when something makes no sense.
They are not silly questions. :c) But getting spoon-fed all the answers will not help you learn in a way that's really useful.
Fast harddrive is important.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
I normally use a good sharp razor blade and splicing tape.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
follow Gees advice - read the guides.
you can edit video on a surprisingly modest setup (I used to do it on an AMD K6/300 with 64Mb RAM), but the faster your system is, the better performance you will see.
7,200 rpm hard drives are a must if you are capturing video. Faster processors and more ram will help in the editing and rendering stages.
for software, it depends on how much hand-holding you want, what your needs are, what your budget is, etc. You may be able to do all the editing you need with Virtualdub, which is an indispensible tool in any case.
more information on your goals is needed for more precise answers.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Em...
I've spent 10 minutres reading thourhg loads of the links.
But... there doesn't seem to be a guide that gives me the information I want.
Fancy giving me a link? -
Originally Posted by jam20002
I'm going to make a different recommendation to someone making movies or music videos than I am to someone capturing tv shows and editing out commercials.
As far as video card, most any modern vid card will be fine - desktop video is not demanding like gaming, most anything with 16mb of ram will be fine.
what software... refer to my first paragraph. I still don't know if you need a Non Linear Editor (NLE) [ie Premiere, Vegas, etc] or if a simple cut editor will do (ie Virtualdub).
what else is important - patience. preplanning. understanding your tools and your aims. knowing when to scrap what you are doing and start over.- housepig
Housepig Records
out now:
Webex recording changes video to side panel. Can I edit with video editing?
By Teenotes in forum Newbie / General discussionsReplies: 0Last Post: 2nd Jul 2011, 12:32 -
Why does the video I edit in Cyberlink look darker after I edit it and post
By Chubby Johnson in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2010, 05:08 -
need help in choosing a format after video edit (DV then edit then DVD)
By shade_2 in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 13:13 -
Womble Video Edit Problem - Scrambled Video?
By slasher911 in forum EditingReplies: 7Last Post: 18th Feb 2008, 16:23 -
black video edit to visible video if possible
By andy in forum EditingReplies: 7Last Post: 5th May 2007, 08:04
