how can i select my cam corder inorder to capture from it in virtual dub?
cheers
I have never got VD to work with DV. Transfer from your DV source to the computer with DVIO or similar and then use Virtualdub (With a DV codec) and it works fine. If you do a forum search on Virtualdub and DV, you can find this has been gone over a few times.
no no, i want to capture using virtual dub, i DONT want to use anything to do with DV, files are far too big.
Windows 7, Virtual Dub (any Version), BlackMagic Intensity Pro = No Capture
By Digital-Overload in forum Capturing and VCRReplies: 2Last Post: 22nd May 2011, 11:57 -
Need help with Virtual Dub setting
By lost123 in forum Capturing and VCRReplies: 12Last Post: 8th Jul 2010, 22:31 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36 -
Some questions regarding Virtual Dub
By smackyourfupa in forum DVD RippingReplies: 3Last Post: 5th Nov 2007, 07:00
