my current chip is a 266 mmx and i have just bought a amd 650,big cartridge type thing,would my heatsync and fan be able to keep the amd stable also i don`t know the make of motherboard so how do iknow if it is able to handle the amd.
2,how do i find hot the teperature my pc is running at?
Not familiar with an AMD 650. You could check the AMD website for info. It sounds like a 'slot A' processor, similar to some of the early Celerons. It's not a high powered processor, so if you have the right heatsink you may be OK. As far as the motherboard goes, usually on the bottom edge, below the PCI slots, the brand and model number is printed. You can do a web search for this and see what you've got. If you have a Intel type motherboard, I doubt that the processor would work, but you can look into it a bit further. As far as temperature, some motherboard bios's can show the temperature. But you do need to find out about the motherboard first.
EDIT: Are you talking about an AMD K6-266? Intel also has the 266 number. Still, try to find the MB model and number. -
it is intel pentium 266 mmx,i will do a searc on the motherboard if i can find the make?
Motherboard repair
By dafoe in forum ComputerReplies: 14Last Post: 10th Mar 2012, 19:49 -
Motherboard Audio
By anirban in forum AudioReplies: 3Last Post: 23rd May 2011, 08:51 -
Downloading Motherboard Upgrades to my Motherboard
By orfajackson in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2009, 15:54 -
Motherboard
By JcMatrix in forum ComputerReplies: 6Last Post: 16th Jan 2009, 03:20 -
pci-e motherboard
By d_unbeliever in forum ComputerReplies: 12Last Post: 23rd Feb 2008, 02:58
