  1. Advise needed
    I have a pioneer burner that has been working fine.
    The last five disks have only burnt 25% to 50% of the disk.
    have been using two types of disk both rytek that have always worked fine for me, untill now, stange if this were a media problem because its unlikely to happen with both types of disk at the same time.
    ? so please lets have your comment do you think the burner is on the way out ( burner only 5 months old) or could it be a gremlin that has altered my system
    ? what would be the most likely cause
    Please can you advise,thanks to all that reply
  2. What are your system specs and what OS ?
    What drive & firmware version ?
    Have you installed any new software or Hardware ?
  3. system is amd athlon 2100 with 512mg ddr ram 120gb hardisk runing widows xp pro
    the burner is a pioneer 105 with f
    firmware 1.33
    its strange because havnt installed anything or added any hardware and things have been running great untill now like I said I tried two completely different types of disk that I have come to trust I now this
    So come on guyes what do you think
  4. Member northcat_8's Avatar
    Mar 2003
    Chit, IDK I'm following you
    Damn Gremlins
    Did you upgrade your firmware or is "f" the original version?
    Do you check your DVD file before burning it? Like with Daemon Tools or something if you are burning from an ISO?
    What software do you use to burn with?
    Try burning from an ISO file if you are not.
    I seriously doubt that it is your media.
    I would also ask if you are doing other things on your PC while it is burning? Even small events like screen savers could possibly disturb your burn process...they shouldn't...but they could.
    You could also try restoring your computer to an earlier time...like when you could burn OK. You never know, some software might have gotten installed without your knowledge.
