    Aug 2001
    When i convert a movie for example
    File : 794 MB (1.0 GB), duration: 0:52:50, type: MPG, 1 audio stream(s), quality: 88 %
    Video : 943 MB, 2496 Kbps, 29.970 fps, 480*480 (16:9), MPG2 = MPEG 2 (SVCD/DVD), Supported
    Audio : 84 MB, 224 Kbps, 44100 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported
    to a vcd mpg, (with vcd pal template.
    The result gets hacky ........-........- how could i improve this?
    Mar 2003
    Uranus
    Look in the guides section for Conversion.
    You are trying to convert a NTSC video to PAL
    That's what is causing the problem. It's not real easy
