I've got a Pioneer 106 DVD-RW and for weeks I was burning my DVDs at 4x with no problems at all...
I was burning from the same place (external 80GB FireWire HDD) to the exact same media... I must have burned 20 discs or so... now I come back a week later... no major changes to anything.... and now I can only burn at 2x without underrunns.... anyone got any ideas why?
Thanks....
I started getting buffer underruns when I was burning from a nearly full HD. If thats your situation, burn at 2x until you've freed up enough space to return to 4x.
I thought about that... but nope... not the case... I've got 35GB free on the drive.... any more ideas?
I think he meant (or should have specified) on your startup disk. You need to have space there so Toast can use it as a scratch disk. Have you tried using a different [hard] drive, like an internal one to burn from? Also, why don't you turn on buffer underrun protection in Toast, so you save yourself the coasters.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
Neither Toast 5 or 6 suppor tDVD Buffer underrun protection on the Pioneer 106. There's been a discussion of this on the accelerate your mac web site. Apparently the solution is to use Dragon Burn instead of toast.
william
Sudden capture problem
By scooter-sf in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 18Last Post: 15th Dec 2010, 09:17 -
Sudden restart
By alintatoc in forum ComputerReplies: 12Last Post: 25th Mar 2009, 10:49 -
Sudden converting problems
By belveder in forum Video ConversionReplies: 4Last Post: 30th Nov 2008, 19:14 -
sudden pixellation problem
By ctjayhawker in forum DVD & Blu-ray PlayersReplies: 4Last Post: 2nd Jan 2008, 20:08 -
All of a sudden every DVD fails
By skeeveman in forum Newbie / General discussionsReplies: 13Last Post: 15th Jun 2007, 08:50
