HI.
i asked an question before about if u could burn several svcd movies on one dvd, and play it on the dvd.
The answer was...if ur player can handle it.
I am qompletly lost in this ......but how do i know IF my player can handle a burned dvd with more then one svcd movie on it?
My player is an Yamaha DVD-S540.
Yes...i have searched for it...just dont understand.
Fredrik
Seem to be very frustrated from your other post..not able to get some straightforward answer!! Well don't be!! lot of guys also have the same predicament. Just be patient.
Anyway the answer to your question is YES. You have a very good player and it can played all format. SVCD is also mpeg2 but you have to change the header. There is a guide around on HOW-TO Search for it. Although I have not tried it but I would recommend that you do a re-code to DVD fully compliant mpeg, it's safer. Just lower your bitrate to 2000 and your file is not much bigger than a svcd
Just got a new Yamaha RX-V367 Receiver. Question about MP3 playback
By jbitakis in forum AudioReplies: 3Last Post: 22nd Jul 2010, 21:12 -
Yamaha DVD-S661
By JCWagener in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Mar 2008, 10:16 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 09:59 -
Yamaha DVD w/HDMI remote hack? Region 1 to all region [PAL]?
By eurocd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jul 2007, 13:58 -
Yamaha DVD-C950 - Pal-to-NTSC Conversion over HDMI
By Big C in forum DVD & Blu-ray PlayersReplies: 6Last Post: 30th May 2007, 14:18
