I used to remember how to do this, but now i forgot. I'm trying to add audio to a still picture for my menu, but I forgot how to do this. I've searched on the forum, I couldn't find the post(s) i was looking for (i know this question has been asked before). Can someone either link me to the posts that talked about this, or flat out tell me?
Here's what I've tried to do so far. I've created a mpegStill using the Tools in VCDEasy. Next i tried loading that mpeg into TMPGEnc but TMPGEnc could not load the mpeg for some reason. I was planning on taking that still mpeg and multiplexing it with the audio file. This way, the still image is the right size, ready to play.
I only have VCDEasy, Photoshop, and TMPGEnc to use, so please don't tell me to get "such and such" program because it will work there. I know this can be done using VCDEasy and TMPGEnc, but i think i'm just missing a step.
Thanks for any help!
Don't create an mpg still, create an mpg. Load that bmp directly into TMPGenc as the video source, then load your audio as the audio source. Then make your settings according to whether you are making a VCD or SVCD. When you encode, TMPGenc will repeat this one frame over and over again for the length of the audio clip. Now import this mpg into VCDEasy and use it as your menu.
Ok, yeah... now it's coming back to me.
Thats what i need to do
Thanks a lot!
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Add audio won't work in audio menu.
By petwes in forum AudioReplies: 0Last Post: 21st Jan 2012, 07:59 -
Continuous play of root menu audio throughout all menu's
By breakbred101 in forum Authoring (DVD)Replies: 3Last Post: 28th Apr 2009, 18:37 -
VCD Menu Lite 2.00
By kbriggs in forum Authoring (VCD/SVCD)Replies: 4Last Post: 16th Mar 2009, 12:23 -
VCD on a DVD with menu?
By capman21 in forum Authoring (DVD)Replies: 5Last Post: 6th Apr 2008, 10:00
