    Feb 2003
    estill sprngs, tn
    i hope this is the right forum, if not mods please move, i ve been backig up dvds, for awile now all have been fine, i just tried to do 2 fast 2 furious 5 times, every time the mpeg was over a gig, ive used setting i always have, and even double checked them any ideas? using TMPGEnc thanks!
  2. more details needed I think - are you backing up to VCD? SVCD? DVD?
    What source are you putting into TMPGEnc - you say backing up a DVD, but how have you ripped the DVD? Are you frameserving with DVD2AVI for example?
    I would have thought it was (S)VCD you're going to, as otherwise a 1gig+ MPEG file would not be a problem.
    What is your usual method? Using the Wizards in TMPGEnc?
    Do you use Source Range to split the movie into 2 MPEGs for 2 CDs?
    If so, sometimes the Source Range behaves a bit erratically, and you have to set the start & end points manually (rather than just leaving the end at -1 or whatever the default is).
    cheers,
    mcdruid.
    Feb 2003
    estill sprngs, tn
    rip using claddvd.net to get d2v and wav, putting single movie on single cd, i use source range to cut ending credits edit= making vcd
  4. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Originally Posted by orion1998_1
    ....ive used setting i always have.....
    And what would those be?
    VCD, SVCD, DVD? What bitrate? CBR, VBR, CQ? How long is the clip?
  5. 107 min long @ vcd std = approx 1.07gb //you silly arse
    problem with tmpgenc sticking to vcd std?? 8) even when settings changed.. update to latest version fixes this..
    The electronic components of the power part adopted a lot of Rubycons.
    Feb 2003
    estill sprngs, tn
    ill try updateing in a bit, what could have changed? i use 0 to adjust the rate, i usally end with a 700-750 meg file and burn the vcd with nero, i have 2 hour movies already on single vcd
