Thats quite normal, and a common problem. Its called overscan and all TV's do it to some extent.
You can fix this when encoding in TmpGenc by using the Video arrange method Center (custom size) and entering a size a few pixels (say 8 0r 10) less than the normal VCD size. The exact amount required to get a perfect fit to your TV screen can only be found by experimenation as all TV's vary.
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
