Hi there,
I've just bought this unit and I have some few questions I cannot find an answer: in order to capture MPEG 2 clips...
1. Is it possible in moviestar to set the CBR capture mode instead of VBR?
2. Is it possible NOT to have a MPEG file splitted?
3. Is it possible to choose a bitrate higher than 8MB (let's say 10) ?
4. Is it possible to change the AUDIO quality ?
Thanks in advance!
Kim
Moviestar 5.x is not a very sophisticated product, and has very little config options, good for the newbie, but annoying for those who are getting more sophisticated.
Not that I am aware of, it makes best quality assumptions, which may be different than what you want.1. Is it possible in moviestar to set the CBR capture mode instead of VBR?
Use a different piece of SW, Hope was next major release would fix the problems, but since the buyout I doubt that will happen2. Is it possible NOT to have a MPEG file splitted?
I don't believe so, actually lots of SW maxes out at 8, so that may be more an issue with compatbility than capability.3. Is it possible to choose a bitrate higher than 8MB (let's say 10) ?
I don't believe so.4. Is it possible to change the AUDIO quality ?
Finding another piece of SW to use for some/all functions might save you the hassle. For example, after the capture, you can take the MPG files and merge them (TMPGEnc has a MPEG merge function).Cendyne/Pioneer 105 & 104 with a Dazzle* Hollywood DV-Bridge. -
I can't believe I can't decide to have a unique file when capturing instead of having more than one file I need to merge later!
Why this? I read that the splitting option is only available with DVC 150 and instead I don't want to use it !!! It is not possible to disable it?
I can't believe it ...
Kim -
I think the file splitting was to guarantee compatibility with Win95/98/Me Fat32, where as the large files could only be written/read NT/2000/XP using NTFS. You figure it should autodetect, or allow customization, but it assumes smaller files size needed (probably was easier to code that way???)
Can the DVC-150 use any other SW (like XP Movie Maker 2) to capture the video? I have the Hollywood DV* Bridge and can use whatever SW. I heard the DVC 100/150/200 is locked into Moviestar 5.x for capture. If so that is one of the reason some people have avoided Dazzle lately (before the sale)Cendyne/Pioneer 105 & 104 with a Dazzle* Hollywood DV-Bridge. -
Currently the only program I'm able to use with DVC 150 is Moviestar.
I have also seen that Pinnacle is updating Pinnacle Studio 8 in order to support also this unit. Perhaps it will work also with it!
Kim -
moviestar 5 or 5.3 is not complete program for capture an edition
i have the solution.
after to try and try i found it.
the problem is that the drivers dvc 150 in to the original pack (with the box) they arent correct and the pinnacle studio quickstart dont work with dvc 150.
the solution is download this driver
http://www.pinnaclesys.com/WebVideo/Stu ... CLEUSB.exe
in actually, im using this drivers with pinnacle studio 9
work in pinnacle studio quickstar, 8,9 !! perfect capture!! drops frames 0
good luck!!
Two Quick Questions about Dazzle DVC 100
By Derangedyeti in forum Capturing and VCRReplies: 17Last Post: 23rd Dec 2010, 23:46 -
Pinnacle Dazzle 'DVC 170' Woahs...
By synthecypher in forum Capturing and VCRReplies: 4Last Post: 3rd Jun 2010, 22:02 -
Dazzle DVC 90 Capturing
By LangleyM in forum Capturing and VCRReplies: 2Last Post: 19th Apr 2009, 10:42 -
Better than Dazzle DVC-170?
By bmbsa in forum Capturing and VCRReplies: 5Last Post: 21st Sep 2008, 07:18 -
audio sync prob dazzle dvc-150 and virtualdub
By zephxiii in forum Capturing and VCRReplies: 5Last Post: 30th Jul 2007, 14:34
