just wanted to know what the difference and which on is better.
i believe that joint stero compares the differences between the streams and theirfore the audio becomes a lil smaller.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>but which on is better -
(True) Stereo is better.
But the file size is *a little bit* larger compared to Joint Stereo. I recommend sticking to (True) Stereo. -
There is no simple answer to this. It also depends on the bitrate you are using...
Joint stereo is relatively more efficient in bitrate allocation that ordinary stereo as it takes advantage of the redundancy between the left and right channel. Thus, at a lower bitrate (e.g., 128 kbps for MP3 and presumable MP2) joint stereo encoded audio will sound better than a standard stereo encoded audio.
However, as the bitrate becomes higher, this factor becomes increasing less and less important. Furthermore, using joint stereo can actually introduce audio artifacts -- but to what degree depends on the encoder. There is also some loss of stereo separation. Thus, at higher bitrates (e.g., 256 kbit/s for MP3 and ?224kbit/s for MP2) standard stereo may offer better quality.
Also, I'm not entirely sure if VCD2.0 supports joint stereo encoded audio for the video tracks... Thus, I woulds stick to standard stereo.
Regards.
Michael Tam
w: Morsels of Evidence -
Technically VCD 2.0 doesn't support joint stereo i don't think but you will probably not find a player that will not play it. By the way joint stereo doesn't really make the file smaller it just makes it sound better for the same filesize. After all 128kbps is 128kbps no matter what encoding scheme....for what it's worth I use Joint stereo on all of my soundtracks which must dip below 192kbps. There is a slight loss of stereo separation (worse at bitrates below 160 from what i have noticed) but I haven't noticed any ill effects in Dolby PL mode....
Preference for MP3 Joint Stereo Vs. Stereo ?
By davexnet in forum AudioReplies: 7Last Post: 27th Oct 2011, 12:49 -
Does anyone know how to convert joint stereo audio back to stereo?
By robrosen in forum AudioReplies: 1Last Post: 2nd Aug 2009, 23:24 -
Stereo VS Joint Stereo
By Anakin in forum AudioReplies: 4Last Post: 26th Mar 2009, 14:22 -
Stereo, Joint Stereo or Dual Channel for Audio input type?
By c627627 in forum Capturing and VCRReplies: 1Last Post: 23rd Mar 2009, 10:33 -
Why joint stereo instead of Stereo with alltoavi?
By regard in forum Video ConversionReplies: 5Last Post: 29th Jan 2008, 05:41
