    Jan 2003
    Nassau, Bahamas
    does anyone know a good looping program possible freeware because i wanna start inserting mpegs into my menu so i can have background motion as well as thumbnail motion....holla back
    "If u cant eat it - u dont need it"
    "Baby - If i dont hit it, Who will?"
    "Why is Abbreviation such a long word"?
    Jan 2003
    Nassau, Bahamas
    come on, 12 plus hits and no one has an answer, i only wanna know how to loop an mpeg so i can insert it into my menu..holla back fellas...
  3. You mean a video for a motion DVD menu? In most DVD authoring software you can set the menu duration to "infinite", that should do what you want.
  4. Try DVD-lab.
    If I understand you correctly that will do what you want.
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    http://forum.doom9.org/showthread.php?threadid=25844
    this technique gets you the mpg. Thereafter its just a case of choosing the correct settings in your authoring application.
