Ok well when i try to use Merge and Cut in TMPG i get the following error AFTER i click on run (which is after i choose where to cut the MPEG 2 in half).
Error: At address 73F91D04, Read error occured against address 73f91D04
then when i try to run it will FREEZE when it gets Output to File.
Anybody ever have this problem, any solutions, i have 40 GIGs if DVD to put on CD's but i can't because there to big, i need help desperatly. BBMPEG or something doesn't work it says
Error: The specified Module could not be found
Damn this sucks..
Pain Heals, Chicks Dig Scars, GLORY...Lasts Forever
Use TMPGEnc to De-Multiplex your file.
Then use bbMPEG to Multiplex the portions you want.
*NOTE* There's a bug in bbMPEG for Windows XP. It 'closes automatically' if you try to load a m2v/mp2 file. To fix this, simply hit the LOAD button on the Main Window of bbMPEG before doing anything, then hit cancel. Then continue as normal.
jerky tmpg
By devdev in forum Authoring (DVD)Replies: 6Last Post: 12th Aug 2010, 08:14 -
Sharp Mini DV firewire not detected by Win 7 but was working under Win XP.
By thintin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Jun 2010, 02:12 -
Win 7 and XP dual boot issues. Can't access one of the drives in Win 7?
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 13th Jun 2009, 22:51 -
Getting error messg "Generic Host Process Win 32 Svcs" now I hv n
By Astrovel in forum ComputerReplies: 1Last Post: 6th Mar 2009, 19:22 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
