Using this guide
http://www.how-to-convert.com/ask_us/a7042003.htm
But no subs will show when i play it on my standalone Nintaus n9900 player.
When I have ripped a file with dvd schrink the subs will show .. so my player must support it..?
But the guide is for svcd so is there a guide when making DVDR ?? or should I only mark the "CVD" in submux ???
HELP!!
SVCD and DVD subtitles are different.
I believe svcd subs are carried in a private stream in the MPeg file.
I think dvd subs are in a private stream in a vob file. The MPEG video is a seperate stream in the vob file.
Suffice to say, an SVCD guide will not work for DVD.
To mux the subs you need to use an authoring progam. Maestro, Scenarist, and IFOEdit are a few tools that can mux subs. If you don't have any, IFOEdit is the only free one.
Here is a guide on how to mux multiple audio tracks. It gives you the basic idea on how to author with IFOEdit, and how to use the results in DVD-Lab if you want menus.
The difference is you would point to a sup file. How do you get a sup file? Well there are some programs such as srt2sup and sub2sup that convert. I think subtitle workshop will convert from ssa to srt.I mean it in the nicest way.
How can I hardcode subs on MPEG2-TS and MPEG-4 files?
By LoveMyslf in forum SubtitleReplies: 7Last Post: 13th Jul 2010, 15:25 -
Hard subs into mpeg2 file using Xmedia Recode
By marioval in forum Video ConversionReplies: 6Last Post: 17th Nov 2009, 07:53 -
MKV whit switchable subs on PS3 becomes 480p instead of 720p??
By bagmand22 in forum SubtitleReplies: 1Last Post: 13th Sep 2009, 07:17 -
Making subs like these
By NangelK in forum SubtitleReplies: 11Last Post: 31st Jan 2009, 12:26 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 16:08
