Just got a Samsung SCD-80 digital camcorder. Got a Belkin firewire PCMCIA adaptor for laptop & a 6 pin - 4 pin cable. Tookme QUITE awhile to figure out the motion to output to DV? With the camera I have to set it into play mode ONLY. With the DVDR75 I have to set it to monitor CAM2, AND record, waiting for signal, waiting the half hour for the PC to generate the temp file and send the DV data.
I am using windows movie maker (I know...I'll buy something decent when I am convinced the functionalty works). Anyway, I am convinced I have the methods down, here is the problem:
PC - Cam works fine. Then I can successfully transfer to DVDR75 using cam 1 RCA inputs.
PC - DVDR75, using same eq gives me a pic that the best I can describe is like the old TV's when the vertical scroll is haywire.....scrolling RAPIDLY up & off the screen, maybe 25-50 scrolls per second. It even keeps this up when I power on/off, eject/reinsert, view menus, etc...it's like the recorder got out of whack.
After several hours of screwing around here is what I found. Same crap as described above onto a BLANK DVDRW, but when I tried to record from TV to that same screwed up disc (got rid of the jitters ONLY by switching to monitor mode/tv)it reported that it couldn't do this onto a PAL disc?!?!
So I put in a unfinalized DVDR with content already on it and sent the video from PC to DV In and said something like, sorry this is an NTSC disc.
Now what the ####....I have used every input on the DVDR75/17 (I am in the US) sucessefully, applied firmware updates about 2 months ago (ff13k), and left it to #### alone as everything works great 'til I use the i.Link. and now I get this PAL/NTSC thing?
I would GREATLY appreciate any ideas on this? Last thing to mention is that I never could get progressive scan to work, just flickers like crazy for a few seconds and then reverts back to Interlaced on my HDTV.
Thanks for any help.
I suggest you to try different software (who knows) I don't have problem with Pinnacle Studio version 8 in my test.
See this : https://www.videohelp.com/forum/viewtopic.php?t=180704Pinnacle Studio 8 and DV home video editing (ver.9 already home)
Problem with Philips DVDR-3505
By obolon84 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 12th Jul 2010, 09:54 -
Expensive or cheap iLink/Firewire cable for video transfer?
By chin569 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 2nd Jun 2008, 11:37 -
best Firewire/ilink card for Sony Hdr-hc5e??
By BrohiBoy in forum Capturing and VCRReplies: 1Last Post: 17th Jan 2008, 01:07 -
Problem with Philips DVDR 3460H
By sonybetamax in forum DVD & Blu-ray RecordersReplies: 2Last Post: 21st Sep 2007, 14:59 -
need help on how to connect sony ilink to macbook on firewire 400
By sasuke85 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 16th May 2007, 23:50
