I am using DVD Shrink. The auto ShrinkISO doesn't seem to work and it takes a long time. All I need is a program that burns .IFO files onto DVD-R discs and for it to be freeware.
Here's the error I get in DVD decrypter when I use autoshrinkISO if anyone can help me with this problem as well.
I installed autoshrinkISO along with the new DVD Shrink and DVD Decrypter. Everything works fine until I get an error in DVD decrypter whne it tries to burn the DVD.
This is what it says:
I 01:46:54 DVD Decrypter Version 3.1.6.0 started!
I 01:46:54 Microsoft Windows XP Professional (5.1, Build 2600 : Service Pack 1)
W 01:46:54 Drive F:\ (FAT32) does not support files > 4 GB
I 01:46:55 Initialising SPTI...
I 01:46:55 Searching for SCSI / ATAPI devices...
I 01:46:55 Found 1 DVD-ROM and 1 DVD-RAM/RW!
I 01:47:00 Operation Started!
I 01:47:00 Source File: C:\TEMPISO\IMAGE.ISO
I 01:47:00 Source File Sectors: 2,299,305 (MODE1/2048)
I 01:47:00 Source File Size: 4,708,976,640 bytes
I 01:47:00 Destination Device: [0:0:0] MATSHITA DVD-RAM LF-D521 A109 (D
I 01:47:00 Destination Media Type: DVD-RW
I 01:47:00 Write Mode: DVD
I 01:47:00 Write Speed: MAX
I 01:47:00 Test Mode: No
I 01:47:00 BURN-Proof: Enabled
E 08:10:50 Failed to Reserve Track! - Invalid Field in CDB
E 08:11:56 Operation Failed! - Duration: 06:24:55
I 08:11:56 Average Write Rate: N/A - Maximum Write Rate: N/A
I would suggest using Imgtool to build your ISO files, then burning the result with DVD Decrypter- I've never had any problems with this method.
You can't fool me, I'm a moron! -
Hey Gargoyle!
AutoShrinkISO based on DVDShrink, ImgTool and DVD Decrypter
mike_hill2107
What would you do with IFO files on a DVD?
Look up the Glossary and Tool sections what is IFO and you can find some other freeware burning tools too!You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
Choppy playback of some MPEG-2 files and all IFO files
By ANOther1676 in forum Software PlayingReplies: 2Last Post: 8th May 2011, 06:04 -
dvd burning/convert program which burns both 4:3 and 16:9 for single movie
By vampelle in forum DVD RippingReplies: 7Last Post: 20th Sep 2010, 03:50 -
Editing .mov files and .ifo/.vob files
By redhot in forum EditingReplies: 7Last Post: 25th Nov 2008, 07:31 -
How to enable the program button on remote control using VIDEO_TS.IFO
By kraw in forum Authoring (DVD)Replies: 4Last Post: 26th Sep 2007, 21:59 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 13:38
