I've uninstalled my previous version of SVCD2DVD+ and installed the i.5 version as I had problems with getting stuck on audio convert where the CPU would go to 80% but nothing happening. Thought this might sort out the problem and give me some new features.
Now I can't even run any version without getting a runtime error, uninstalled and reinstalled a dozen times with the same result.
HELP!!! please
Results 1 to 9 of 9
DaveDaviesGuest
Dave,
Have a look at the the end of this post:
https://www.videohelp.com/forum/viewtopic.php?t=180955
Whilst it applies to the demo it may help you also.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
DaveDaviesGuest
Chris
I have already downloaded and installed version 1.1.4322.573 from MS earlier this morning to eliminate that one but trying your link now.
Will let you know how I get on. -
ok - sounds convoluted but try this:
- uninstall 1.1
- install 1.0
- install 1.1
in that order.
(one of the dlls requires 1.0 the others 1.1)SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
DaveDaviesGuest
well what can I say other than "STUPENDOUS" it worked.
Once again, many thanks for helping me out Chris. -
I'm just sorry the .Net framework is such an (_!_)
On startup, keep getting a Common Language Runtime Debugging Services alert
By Carl III in forum ComputerReplies: 1Last Post: 18th May 2010, 17:04 -
runtime error
By ram16 in forum Newbie / General discussionsReplies: 9Last Post: 20th Dec 2008, 23:04 -
Runtime error
By Illusionist in forum ComputerReplies: 7Last Post: 13th Jul 2008, 00:01 -
Runtime Error
By clivedavies328 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 17th Jul 2007, 15:33 -
Common Language Runtime error
By scrtagt69 in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 2nd Jul 2007, 03:42
