  1. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    Virtualdub, by default, gives the captured file the name "CAPTURE".
    I know you can change this but I find that if you're capturing many clips in a short space of time having to rename each capture before capturing the next is a real pain.
    What would be better is if, by default, Virtualdub captured as "CAPTURE1", "CAPTURE2", "CAPTURE3" etc.
    This may well exist as a function but if it does I can't find it.
    Anyone know of a fix, workaround etc. or am I to suffer forever?
    Many thanks,
    Will
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
    Apr 2002
    The State of Frustration
    Does this help?
    Hello.
  3. Lost Will Hay's Avatar
    Oct 2002
    Originally Posted by Tommyknocker
    Does this help?
    Certainly does, although I think I may have an earlier version (I'll check tonight).
    Thanks (for the 2nd time today)
    Will
    Apr 2002
    My pleasure.
    Hello.
  5. Lost Will Hay's Avatar
    Oct 2002
    Thanks again pal,
    Will
