How do i convert my divx 3.11 apocalypse now movie into a
Divx 5.1 movie?
What program will do this and how do i do it?
I have a ltieon lvd 2001 that can't play the acopalypse now movie
withs its fast parts or in the first 12 seconds of the movie.
Thank you for your help.
Indo Fear
Make sure you have all the right codecs installed (probably just DivX 3.11 and the latest DivX 5), then use VirtualDub.
Just open your file, select Video->Full Processing Mode
..then Video->Compression, and set up your DivX 5 codec.
You'll probably need to use a bitrate calculator (several in the tools section) to work out the settings.
Then File->Save As AVI.
That should be about it.
cheers,
mcdruid. -
just wondering what the point of this would be ? other than making the quality worse ...
Apocalypse Now Meets Winnie the Pooh
By Soopafresh in forum Off topicReplies: 0Last Post: 24th Feb 2010, 03:22 -
How can I convert a widescreen movie to full screen movie on PSP?
By VidHunter in forum MacReplies: 2Last Post: 9th Nov 2008, 23:20 -
How do I convert DVD movie to DIVX w/o Audio Syncs problems
By peggypwr1 in forum Video ConversionReplies: 10Last Post: 1st Aug 2008, 18:22 -
Resident Evil First movie ...Not Apocalypse the 2nd movie backup issue!!!
By vanc in forum DVD RippingReplies: 0Last Post: 19th Oct 2007, 12:33 -
How to Convert 1280*720 DivX to a less dimensions DivX
By firas_hashim in forum Video ConversionReplies: 9Last Post: 27th Jun 2007, 09:33
