  1. I'm trying to backup the movie Remember the Titans, but when I use DVD Shrink the picture is fine but there is no audio. I've tried several times trying to use different audio choices and none of them work. Please Help!
    Jan 2002
    Australia
    Dont remove any of the "Audio" choices, that should work, DVD Shrink will
    adjust it to 4464 Gb anyway.
  3. I have found that with some DVDs if you remove an audio track then you have to go into the audio options when you play the resultant disc and manually select the audio choice you have retained.
    I had this problem on Daredevil when keeping the DTS track and discarding the AC3.
    Zen
  4. Member wulf109's Avatar
    Jul 2002
    DVD Shrink simply copies the ifo file,which controls how the disk plays. Your player will default to the first audio track,if you don't check the first audio track in DVD Shrink's window you won't get sound on your DVD player unless you cycle with the remote.
  5. Thanks for the replies, using my remote fixed the problem.
