I was trying a variation of the motion menu creation in TCSV. Actually, what I'm trying to do is create a "title screen" that just as the play movie option. I want it to just loop on that MPEG until I go to the next.
Anyhow, I followed procedures that Marty posted. I then create the cue/bin file no problem. When I then go to the CdRao tools to simulate a burn, I get the following error in the log:
ERROR: C:\Program Files\Pinnacle\Studio DV\movies\UnitedWeStand.cue:1: Illegal token: F
C:\Program Files\Pinnacle\Studio DV\movies\UnitedWeStand.cue:1: syntax error at "EOF" missing { Binary Motorola }
It is like the cue file was written wrong. I then tried to close TCSV and use VCDImager Easy 1.0.1 to write the file I created tith TCSV, and I get the same error. (VCDImager Easy doesn't support menus, so I can't generate from there directly.)
Any advice?
For the record, if I write from VCDImager Easy using CDRAO, it works fine...it is only when I tried this that it fails.
Hmm. So far no advice. I'm still experiencing this problem. Anyone have any ideas? Please? This is the final step I need to finish a VCD I am making.
I always got that error and then one day i saved the bin and cue file to my d drive and it actually worked. You could try your root drive. Don't save it in a folder like my documents, you don't want to have any spaces in the cue file where it points to the bin file.
(c:/my documents/movie.bin"change so there is no spaces in the name.
ps. make sure your burner is supported also.
i hope this helps. good luck
DVD Architect Pro 5.2 error writing file?
By dabezt in forum Authoring (Blu-ray)Replies: 7Last Post: 30th Aug 2011, 07:55 -
ShowBiz DVD 2 Error - Failure writing the disc
By smbcingu in forum Authoring (DVD)Replies: 4Last Post: 2nd Jan 2011, 16:34 -
Error in writing a YUV frame
By krao in forum Newbie / General discussionsReplies: 11Last Post: 1st Sep 2009, 10:47 -
DVD writing error
By nathy85 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Nov 2007, 17:00 -
Error writing to media
By minepup in forum DVD & Blu-ray WritersReplies: 2Last Post: 21st Jul 2007, 07:28
