Hi there dudes !!!!![]()
I have a digital camera and I recorded couple of movies.After that I decided to make a VCD. But i couldn't find the right encoder to convert the QTclip to a supportable file so that I could burn it to a cd.I finally found the encoder.And I have a problem now because my younger brother deleted my whole disk C.Right now I'm trying to find this program I'm sure of it that this encoder was on this web site for free.Although I looked around and I haven't found it.So please guys if you know any encoder that can convert QTclip to a supportable format so that later on it'll be capable to rip. Thx dudes. and I hope you dudes will help me with my problem. bye
Was it this one?: http://www.divx-digest.com/software/mov2avi.html
Found through here: https://www.videohelp.com/tools.php#VideoEncoders
May be others there for you.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Hi there dudes !!
Thx for your help
I went to see the link u guys gave me but none of the encoders work
.When I try to encode the video I get a message unsupported format. I've had this message before when I tried to get the right encoder and I found it. But now i have no clue where can I get it from. Damn it.By the way is therea diffrenece if I'm looking for an encoder or converter ?It's on this website somewhere for sure. Thx agian for your help guys I appreciate it.
By the way what's TMPGEnc Mov Plugin ?? how can I find it f its TMPG ? -
You have to download TMPGEnc first (a link to its tools page should appear there automatically where it says TMPGEnc).
Then download the TMPGEnc Mov Plugin (again that text should be a link to the tool page).
When you've downloaded the plugin, you probably have to unzip it (use UltimateZip if you don't already have a program for archives).
You'll then have a file called QTReader.vfp.
Copy this file into the main folder where you've installed TMPGEnc (i.e. into the same folder as you've put TMPGEnc.exe.)
TMPGEnc should now be able to open QuickTime files. There are lots of guides about how to use TMPGEnc on this site.
These ones might be particularly useful for you
You'll need to have the QuickTime codecs installed of course - get them from Apple's QuickTime download site.
Do the full installation when you get the option for Compact/Full(Recommended)/Custom etc..
Good luck - and keep your brother away from your computer!!
cheers,
mcdruid. -
It's me again 8)
I did the procedure you gave me above but tha'y not exactly what I meant.The problem is that I need some ptogram to encode the quick time clips that are from my digital camera.They are in an unsuported format and when I try to burn them on a cd I can't.So i'm lookinf for a program that I'm gonna be able to change the format so that I will be able to play it as a VCD in my DVD player. I know one thing that I've got this program from this site. Thx for your responds dudessssss. -
If you follow the steps above, TMPGEnc will be able to open QuickTime clips. It is an MPEG encoder, and therefore is able to encode anything it can open into MPEG-1 (VCD) or MPEG-2 (SVCD/DVD) - although the latter is time-limited in the trial version.
If TMPGEnc is not opening the clips from your digital camera (once you've installed the QT plugin), then they are not normal QuickTime clips.
What does gSpot say about the clips your camera produces?
What file extension are they saved as by default? (.avi, .mov etc..)
TMPGEnc will do what you have described if you follow the instructions above, so maybe what you are trying to do is not quite what you have described to us.
cheers,
mcdruid. -
What's up there dudes !!! 8)
I finally resolved the problem.I must have done something wrong before becasue it didn't work.But now it works and I'm able to record it as VCD format. Thx for your help
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 09:13 -
Your Best Video Encoder/Re-encoder???
By iqbal88 in forum DVD RippingReplies: 2Last Post: 15th Aug 2011, 08:09 -
Hc Encoder
By pcb in forum Video ConversionReplies: 12Last Post: 28th May 2010, 13:15 -
Error with Nero AAC encoder in XVID4PSP - "Could not open AAC encoder&
By TheViking in forum Video ConversionReplies: 2Last Post: 5th Nov 2009, 01:41
