Hello, I'd like to be able to run Nero from a CD, is this possible? Maybe even a thumb drive...
Morpheus - I remember that I am here not because of the path that lies before me, but because of the path that lies behind me.
It seems to me if you burn the directory onto a CD, it should work. I do not know if it will work on every computer you stick the CD in. All the .dlls and such PCs use are sometimes not in the main program directory. But the bulk of the program will still be on the CD.
Hello. -
Yes you can do that but I don't see the advantage of doing so. In fact it's a bad idea. First of all it's slower that running from a HD and less stable, and may result in a bad burn.Secondly you can only use it on your pc and not another because the necessary files must be in window and the registry for it to work properly. Thirdly you must ensure the drive letter of your cdrom remain the same if you add new hardware to your pc and the temp files must be located on your HD
Thank you both for the replies. I realize that this i a bad way to do things, but at this point it's my only option. I would like to download... something... on a particular computer that happens to be on a T3 line. The speeds are amazing, 1.5mb/s+, only drawback is that there is security set up so you can not install any more software. I plan to get around this by installing burning software on a CD or thumbdrive and running it from there. I'm not really concerned with it being optimal or not, just that it will work once or twice. I'm going to try the thumb drive option. Wish me luck...
How do I install Nero Showtime and only that?
By fk in forum Software PlayingReplies: 0Last Post: 16th Apr 2008, 04:17 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 14:43 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 22:09 -
Use without an install
By raschko in forum Newbie / General discussionsReplies: 0Last Post: 9th Aug 2007, 17:37 -
install
By Brasilman in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 29th May 2007, 10:17
