I jus burned a svcd2dvd w/ that software and it says in my dvd player
something about not valid region code. Can I change w/ region code w/ this application.
neXus128Guest
neXus128Guest
what if it was in pal mode instead of NTSC, how would i switch it then using the prog? I dont think i can w/ this prog can I??
the dvds are regionless. Is it the old NTSC vs PAL issue?
neXus128Guest
okay, ill give u the low down jus so it helps...
i was trying to do ................ and it was getting played on a sony dvd player...dunno the model off hand...but ya it gave a error msg that dealt w/ one of the issues i mentioned above...all in all it wouldnt play the disc
cannot change region code from 1 to 2
By decocal in forum Software PlayingReplies: 6Last Post: 16th Oct 2009, 05:27 -
Can't change region code
By The-One in forum Blu-ray RippingReplies: 0Last Post: 22nd Mar 2009, 12:19 -
Change Sony BDP- S350 From Region (1) to Region (4) can it be done?
By MOTHGIRL in forum DVD & Blu-ray RecordersReplies: 1Last Post: 30th Sep 2008, 22:58 -
Region change
By ndreichner in forum DVD & Blu-ray PlayersReplies: 4Last Post: 20th Sep 2008, 16:00 -
Audiovox PVS69701 Region Change
By gelethian in forum Portable VideoReplies: 0Last Post: 27th May 2008, 15:23
