Now, I know I've asked a similar question before, but I'll explain everything this time:
I ripped a trailer from a DVD (NTSC), and went to copy it to a DVD-R, and here is what I did:
1) Opened SmartRipper and ripped the trailer from the DVD.
2) Used DVD2AVI's default settings to create an audio track and a d2v file.
3) Used TMPGenc Plus and reencoded the video. I used the DVD NTSC template, and left the encode mode in Interlace.
However, when I went to view it on my DVD, you could easily notice the interlacing, and well, it made it look like crap. What can I do? I was told by some to keep the interlacing, but the interlacing almost gave it a headache inducing look.
Is there a way to fix this?
Two possibilities spring to mind here (though neither may be right
1) The original trailer was not interlaced. If it was originally shot on film, this is quite possibly the case.
2) You selected the wrong field order in TmpGenc. Try re-encoding with the field order reversed.
audio delay after encoding, but not after ripping the DVD
By codemaster in forum DVD RippingReplies: 18Last Post: 21st Mar 2011, 17:03 -
Auto ripping / encoding tv shows?
By springs in forum DVD RippingReplies: 1Last Post: 29th Dec 2009, 10:40 -
De-interlacing & Encoding problems.
By rossfcp in forum MacReplies: 1Last Post: 29th Aug 2009, 22:32 -
Off sync audio problems - is it ripping or encoding?
By kirklt in forum DVD RippingReplies: 3Last Post: 14th Jul 2009, 11:48 -
Good Video Explaining Interlacing and De-Interlacing
By Soopafresh in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2008, 20:50
