Hi
I have some MPEG files (about 45 mins in about 450 MB, guess its VCD format) which I want to burn to DVD.
Using TMPEGEnc for it, but unsure how big the resulting file should be.
How many of these movies can i burn on one DVD without losing very much quality?
If i go for 4 files per DVD, i get a file of about 1 GB with a bitrate of 3000.
Not sure what the difference between MPEG-1 and MPEG-2 is, but shouldn't MPEG-2 be able to create smaller files, not bigger ones, with same quality due to more advanced compression?
The movies are in 320x240 or 352x240 so i don't mind using 352x576 resolution...
So what bitrate is "safe" to use?
Thanks for your help
Originally Posted by Kronos2000
If your files are in fact VCD, then the video is DVD compliant and should be burned to DVD as is, do not re-encode. Re-encoding will only result in a loss in quality, you cannot make it any better. The audio may have to be resampled to 48 KHz though and how many will fit on a disk depends on the size of your files. Look in the guides for VCD to DVD."Art is making something out of nothing and selling it." - Frank Zappa
how can I reduce bitrate and frame rate when converting avi to mpeg-2(dvd)?
By jasoothai in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2011, 03:42 -
MPEG Question regarding specs (Bitrate, Ratio, Resolution)
By hcowan in forum Newbie / General discussionsReplies: 5Last Post: 31st Jan 2011, 15:26 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Bitrate question compiling a DVD
By dvdnewb2 in forum Video ConversionReplies: 6Last Post: 18th Aug 2008, 08:31 -
MPEG-2 bitrate > 4000 with DVD Xpress DX2?
By miamicanes in forum Capturing and VCRReplies: 2Last Post: 11th Sep 2007, 09:12
