  1. How can you slow down the speed of an mpg in order to create a slow motion effect? There must be a way!
    Cheers.
  2. There are many ways... almost any video editing program would let you change the speed of the video.
    However, there is no way of doing this without re-encoding the MPEG.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  3. Which programs can do it?
    Can any freeware programs do it?
    Would the frame rate have to be change? [My source is Pal 25fps]
    Cheers.
  4. You don't have to change the frame rate ofthen the software will have a filter that can do this. I think MovieXone can do this:
    http://www.aist.com/
    that's freeware. Aist as several commerical, freeware, and trail programs you should be able to find something that works. I think MovieDV is also freeware? Forget the links but there's a program Vegasvideo that also freeware and pretty nice.
