I am trying to copy audio / music from a few games and applications that I have, that output thru my sound card - actually the on-motherboard AC97 sound device. I am trying to use audacity, from which I am able to select a source to record from. However I am unable to "capture" the audio, as audacity records blank. It seems I can select the audio sources (line in, microphone, cd-audio, tv tuner) from the audio.
Question is, does anyone know a way in which I can do this, record sounds played thru the audio card? Again I dont have an audio card, just the on-board audio - Avance AC97 Audio. If there is anothe rprogram besides Audacity that can do this, and/or if I need to install an actual audio card to accomplish this, I will.
I also have an ATO 7500AIW video card, which "pipes" its audio out into the AC97 in, and I was able to test record audio from a TV show without any problem, as the audio sound records was then set to the line-in, so at least the audacity does work for "external" sources.
Patrick
https://www.videohelp.com/forum/viewtopic.php?t=181115&start=0&postdays=0&postorder=asc&...=record%20hear
Check that thread out - someone asked a similar question a few days ago
[VHS conversion] Sound Card, Video Card?
By bessiecat in forum Capturing and VCRReplies: 6Last Post: 26th May 2011, 13:02 -
HD audio formats, Home Theater Applications, ripped BD's
By runLoganrun in forum Blu-ray RippingReplies: 1Last Post: 14th Feb 2010, 21:14 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 16:13 -
Capturing Audio in Sound Recorder
By ViRaL1 in forum Off topicReplies: 3Last Post: 2nd Dec 2008, 02:26 -
PCTV Rave Card - trouble capturing xbox + tv audio
By chocolate_brownie in forum Capturing and VCRReplies: 2Last Post: 24th Jul 2007, 08:38
