preferably +/-
thanks
Results 1 to 9 of 9
Personally, in my own *OPINION*, I don't think that "reliable" and "under $200" can both be used to describe any single DVD burner.
See current issue of PC Magazine (28 Oct cover date) for extensive, thorough test of burners. Although only one is below $200 (LaCie Dual) they must list recommended prices as I only paid $130 for one that they list at $269.
Pioneer DVR-106 (+/-) for $153.00...
http://store.yahoo.com/meritline/index.html -
Here is a DVD writer for under 100 bills
http://www.tigerdirect.com/applications/searchtools/item-Details.asp?EdpNo=587576&sku=...RCCODE=WEM556C
89.99 after a 20.00 rebate -
There are all KINDS of 'em for <$200. Pioneer, Sony, NEC, Lite On, Optorite (Sanyo)... About the only one that ISN'T is the Plextor 8x and probably the other 8x ones when they finally arrive.
Right now it seems that the cheapest DVD BURNER that supports DVD-R and DVD+R (as well as -RW and +RW) would be the NEC ND-1300A
For around $120 USD with shipping it can't be beat.
I've had one now for a couple weeks now (I wanted 4x writing and my old DVD BURNER was 2x only) and it has been working great and so far I've been using the firmware it came with (version 1.05)
I would also recommend the NEC 1300A. I have it and a Pioneer A05. I use the Pioneer on cheap media, and the NEC for name brand stuff. I would consider the media you plan to use first however, this drive doesn't get along with generic media very well. If you are going to use cheap media, I would get the Pioneer A06. As far as the <$200 goes, you can get almost any dvd writer for that budget.
the top right corner of the main page always has three writers you can get & where to get them & what the price is StiCckYfiNgAaZ & you didn't tell us what kind of computer you have .....
Please recommend reliable Portable Digital TV
By V Bot in forum Portable VideoReplies: 2Last Post: 9th Oct 2011, 12:28 -
Most reliable DVD burner?
By alvabass in forum DVD & Blu-ray WritersReplies: 2Last Post: 15th Jun 2011, 08:19 -
Could someone recommend a good SATA CD/DVD burner?
By Jonathan in forum DVD & Blu-ray WritersReplies: 7Last Post: 25th Feb 2011, 00:41 -
Fastest reading, most reliable DVD burner?
By Sephiroth666 in forum DVD & Blu-ray WritersReplies: 31Last Post: 8th Mar 2009, 13:45 -
Hey can tell me the best performing, most reliable CD/DVD Burner & Medi
By uncleB in forum DVD & Blu-ray WritersReplies: 26Last Post: 8th Feb 2008, 15:22
