Where can I find cool transitions like you see in football games and other live tv shows? Is it possible to make these?
If you've got a good imagination, a good video and image editor, you should be able to create anything you want.
I create 95% of transitions and 100% special effects using Photoshop and Premiere. Tools like Adobe After Effects and Ulead Cool 3D, would also come in handy.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Originally Posted by FOO
Yes, as a previous poster says, After Effects. Indeed, that's what a great many of those transitions you see on TV are created in.
There's almost nothing it can't do -- the downside is that it's pretty expensive (although if you don't need advanced keying and stabilization you can just get the standard edition, which is about half what the pro version costs)."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang
make movie with images and transitions
By J@Y in forum EditingReplies: 6Last Post: 4th Nov 2011, 21:35 -
What is Best Software for Slideshow Presentation Videos? Cool Transitions !
By zcity1 in forum Newbie / General discussionsReplies: 1Last Post: 17th Aug 2011, 13:11 -
what transitions to use and when ?
By codemaster in forum EditingReplies: 12Last Post: 22nd Mar 2011, 14:03 -
Transitions make static in Arcsoft Showbiz MPEG2
By Canopus Smoker in forum Newbie / General discussionsReplies: 1Last Post: 25th Nov 2008, 22:10 -
how can i make transitions
By wan2no in forum Authoring (DVD)Replies: 3Last Post: 14th Jun 2008, 18:33
