Hi all,
I have an asf movie file I want to convert to VCD or SVCD on my mac. I am not at all sure how to do this.
Euro
Results 1 to 21 of 21
Load it into TMPGEnc Plus. Select Load, choose the template. Select filename of your finished video. Press Start. When done, the new file should be (S)VCD compliant, depending on which template you selected.
Hello. -
Tommyknocker
you know this is the Mac Forum do you not!
Forum Rule:
Please try to post in the right forum. This forum is for Mac Video Forum.
euro
will this file play in Mplayer? If so there may be a chance of doing this conversion. -
Sorry, now I'll never get the smell out of my computer room.
Hello. -
Smell, what smell?Sorry, now I'll never get the smell out of my computer room.
no problem
just a question really.... how is it that you [and others] post replies in here and not notice its mac forum?
Forum search leads you to a particular post?
Just curious about whats going on in mac forum?
just curious is all. -
It's like taking a Sunday drive. One wrong turn, and you're in the ghetto
Hello. -
and with 3 posts now your addicted! -
Yeah, once you start slumming, you cannot just "turn it off". It's like a cold. You have to let it run its course.
Hello. -
right, well enough of this... otherwise ill have to move it to offtopic.
no more replies by either you or me until we hear something from eruo -
ASF to VCD. Have fun with that. The only way I was ever able to accomplish that was to use VPC.
dont you just love ffmpegx. Maybe when we finally hit v1.0 it will be able to run our entire lives for usOriginally Posted by major
Yep, that worked major, I now have the audio.
So I set the wizard to SVCD and go?
In the save as portion is this specifying a directory? or filename?
Thanks Euro -
Major,
I have hit a snag....
I got a framereate error when using the SVCD wizard and selecting the audio track=1 and mplayer decode....it said only standard frame rates can be used with mpeg2enc engine....defaulting to NTSC FILM then it seemed to hang the program (did nothing for a long time).
The info on the file is:
Video [1VMW] 320x240 24bpp
audio codec: framecopy (format=161 chans=2 rate=44100 bits=16 bps=8005 sample=1487)
I am not too sure how to set up ffmpeg to process this file....any help would be appreciated as always.
Cheers,
Euro -
Sorry. I posted a question to this original thread, and then after searching and searching, I found the answer. If I had been able to delete the post outright, I wouldn't have bothered you at all.
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 11:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 21:25 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 09:34 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 11:27
