Hi- I have scanned the search on here endlessly and am not finding the answers I need. I have a movie in BIN/CUE format, checked it with notepad, and burned the image with Alcohol and Nero. The DVD player says it cannot play the disc, but I have watched VCD's on it, so I assume SVCD would work. Any help on this? Hopefully I have given enough info. Thanks!!!!
Firstly, are you even sure that the CUE/BIN image is good?
Have you tried playing the disc back on your PC with a software DVD proggy that understands SVCD? (e.g., WinDVD).
Regards.Michael Tam
w: Morsels of Evidence
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
