Hi,
I encoded a dvd as a VCD. As a result, I get tons of file. One .mpeg of the whole movie, two .mpeg, which are the first file split in two, and some .cue/.bin files.
Which one am I suppose to use to burn a vcd with Toast 5.2 ?
Toast does not accept the .cue files because it says quick time can't read it. As for the .mpeg file, it says there is no video in it !
I have no clue how all this works. If someone could tell me how to burn a VCD that I can play on a DVD player, I would greatly appreaciate.
Thank you.
jubneqGuest
To burn in Toast 5, open the VCD tab in Toast, and drop the .bin file saved by ffmpegX (one .bin for each CD), and burn. You can trash the .cue files, as well as the two .mpg chunks. You could keep the .mpg of the whole movie if you want to watch it on your computer later, or you can also trash it.
jubneqGuest
Thanks a lot. I don't know why I tought the .cue file was needed in order to make a VCD.
How to rip a copy protected VCD and then burn to a CD
By c1steady in forum Authoring (VCD/SVCD)Replies: 4Last Post: 17th Jul 2009, 14:11 -
By c1steady in forum Newbie / General discussionsReplies: 3Last Post: 17th Jul 2009, 06:40 -
How can i burn a DVD or VCD with subtitles?
By Krimoon in forum Newbie / General discussionsReplies: 2Last Post: 25th May 2008, 15:41 -
how to convert and burn avi to vcd with cusoft
By brandon334 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 21st Apr 2008, 18:49 -
Burn .avi file to VCD while still retaining subtitles
By Holymoly in forum Video ConversionReplies: 1Last Post: 12th Dec 2007, 21:30
