I'm using clone dvd... I copied "Cast Away" and couldn't get any sound for the longest.. I finally figured out that even though I successfully have copied other movies with DTS/6 sound, that those movies didn't have DTS/6 on top of the clone list and so the first choice.. that is was usually second, with AC-3/2 as first or AC-3/6?
I understand that my player must be able to play DTS/6 in order to hear DTS/6.. but why won't it default down to the next one if DTS/6 is not supported by the player?
Am I wasting space on the cd, to even record mulitple formats if my player won't support it? ( I use the KISS dp-500) and toshiba 1712 in my computer.. neither seems to play it..
In order to get sound to work with cast away.. I simply had to "deselect" the DTS/6 so it didn't even copy it.
What would you suggest?... just always deselect DTS/6?.. or is there a way to "move it down the list" so my player will play whats on top, but if another player that Supports DTS/6 plays the cd, it will play?....
There's still alot about clone dvd that is hidden and puzzles me..
And alot I have to learn about dvd backup.
thanks.....
Results 1 to 1 of 1
Don't do it, if you can't chew it!!!
DTS sound from DVD
By night_flight in forum Authoring (DVD)Replies: 8Last Post: 11th Apr 2012, 18:59 -
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 14:54 -
Please Help? How to restore DTS sound on DVD
By amir3852 in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2011, 16:31 -
No sound when converted, going top ipod, using SUPER
By wolfman13 in forum Video ConversionReplies: 1Last Post: 2nd Feb 2009, 10:17 -
AC3 sound - worked in software, didn't on set-top player
By dadrab in forum Authoring (DVD)Replies: 12Last Post: 25th Feb 2008, 08:15
