I'm converting my collection of DVD's to VCD's using DVD2AVI and Tmpgenc. After loading the mv2 file Tmpgenc will judge the field then fills out the rest of the data. Even though my DVD are different as far as the aspect ratio ( 4:3, 16:9, letterbox etc) Tmpgenc treats them all as 4:3 702X480 NTSC files. Should I manually change these settings according to the DVD??
If you are using the tmpgenc wizard (which I highly recommend) then the default 'video input setting' is 4:3. You need to manually change that to 16:9 ntsc(unless it's european and then it would be pal). The 16:9 setting should only be that if dvd2avi says that is the setting. Now, you can change that in tmpenc output by going in 'other settings' and change the video arrange to 'full screen no margin'. This will change a true widescreen to amaphoric and an amaphoric to full screen. go to http://entiendo.gotnet.net/ for clarification
Settings TMPGEnc to FFMpeg
By Nologic in forum Video ConversionReplies: 0Last Post: 5th Apr 2012, 22:15 -
TMPGEnc Settings?
By chronic777 in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 09:14 -
Help with TMPGEnc 4.0 XPress Settings
By mister_to_you in forum Video ConversionReplies: 0Last Post: 20th Jun 2008, 09:01 -
TMPGEnc DVD settings
By Bully9 in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2008, 08:22 -
Doubt about TMPGEnc Plus' settings
By alvabass in forum Video ConversionReplies: 1Last Post: 13th Jun 2007, 11:52
