Hi
I have an mkv file with dual audio tracks and subtitles that i want ot convert to vcd-compliant MPEG-1. I have done this successfully with many other mkv files using VirtualDubMod (usually i demux and get an .avi, an .ogg, and a .srt). This paticular file, however, makes VDM crash just as it start "parsing makstroka file". It gives me the crash box. I saved the crash info if u want it.
i can open it fine graphedit tho... it plays fine basically
Is there another way i can demux the video stream and one audio stream and the subtitles...?
Thanx alot!
ok getting new mkv errors with 2 different mkvs, different problem: VDM while parsing the mkv file says: "No duration for subtitle"...
What does that mean, and is there another way to demux an mkv file??
Thanx -
Hi,
I'm no expert on this, but as I write I am converting an mkv file to VCD using TMPGEnc. At first TMPGEnc refused to open the file, but after installing the Matroska Playback Pack ver.5, and installing the FFDSHOW (both available at the Matroska site) TMPGEnc will open both the audio and video without any problem (in Win2000). Maybe this will work for you as well. -
Tmpgenc can open MKVs???!! w/ directshow and mkvplayback pack ...
the only problem is my mkv has dual audio tracks - I want the second one!
Thanks for replying -
ok prob solved on the two mkvs with the subs prob... used mkvmerge (u can get it from official site)
but the other still messed up, downloading alternative - good old avi =)
MKV Demuxing Problems
By Justin123 in forum Video ConversionReplies: 2Last Post: 10th Jul 2010, 02:33 -
Problem demuxing bluray mkv
By kadyn67 in forum Blu-ray RippingReplies: 0Last Post: 1st Jun 2010, 19:31 -
VirtualDubMOD crash
By BlundaKat in forum Video ConversionReplies: 4Last Post: 28th Sep 2009, 09:17 -
VirtualDubMod Access Violation Crash
By k3yword. in forum EditingReplies: 1Last Post: 29th Jul 2008, 20:19 -
VirtualDubMod crash!
By fruitpassion in forum Video ConversionReplies: 0Last Post: 1st Aug 2007, 15:06
